Larry's fuel problem
Michael Soldan
01-19-2001 07:25:29
Larry ,I've read all the responses to you problem. My son's Jeep Laredo did the same thing, after new filters ,tank check ,pressure test ,we discovered a small piece of rubber off of the hose cutting swirling around the entry to the carb body. The Jeep would idle nicely but as soon as we put demand on the engine it bogged. It sounds like you have been thorough in your trouble shooting but maybe it could be something like this.I'm very careful now cutting hoses and I inspect them carefully beforeinstalling them .Good luck From Mike Soldan in Exeter Ontario Canada
Jim
01-20-2001 14:39:33
 Re: Larry's fuel problem in reply to Michael Soldan, 01-19-2001 07:25:29
Back to the possible vapor lock idea. I was reading an automotive magazine today when something in an article made me think of Larry's fuel problem. The article spoke of adding ac/refrigeration foam insulation around fuel tubes to help reduce fuel temperatures and thus reduce chances of vapor lock.
