MF 65 3pt hitch
Todd from IN.
01-15-2001 08:27:08
I'm sure is a stupid question, but does my MF65 have Category 1 or 2 hitch??
Todd from IN
01-18-2001 08:46:28
 Re: MF 65 3pt hitch in reply to Todd from IN., 01-15-2001 08:27:08
Thanks for the help. I have two holes that I can attach my top link to. My top link I know is a cat 1, and works fine in the lower hole. But if I try to use the upper hole, my top link barely reaches. Is this only for cat 2?? is there any advantage to using the top hole??
RayE
01-16-2001 18:00:04
On the 65 i had you could change the arms on the
end and use either cat. 1 or 2 arms.
Jack in NB
01-15-2001 11:05:15
Hi Todd-
First, there are NO stupid questions.
There are a lot of technical terms in most fields, often designed deliberately to confuse the rest of us - and usually cost us money to find the translations! (read: Microsoft!)
The 65 had Cat 1, Cat 2 and sometimes both! If your pin holes are 7/8", it's Cat 1, if 1 1/8", it's cat 2.
Pat
01-15-2001 17:59:33
 Re: Re: MF 65 3pt hitch in reply to Jack in NB, 01-15-2001 11:05:15
While on the topic, what exactly is the difference with respect to load rating, etc. between a category 1 and category 2 hitch?
