MF 175 PTO
jc
01-15-2001 05:45:15
Have a MF175 w/perkins diesel. Eight speed. I have a 3 pt self-contained backhoe on it (with loader). The problem is I can't engage the pto (with clutch) while the tractor is running. I have to shut it off, engage it, and start it? Is there a clutch adjustment for this?
Vince
01-19-2001 07:20:20
 Re: MF 175 PTO in reply to jc, 01-15-2001 05:45:15
I too, have a 175 Massey with the same problem. I have to shut the tactor off to be able to engage the PTO and then re-start. I am not able to stop the PTO by pushing in the clutch (slows down temporarily, at times, but doesn't stop). I've tried adjusting the pedal/linkage, but it doesn't seem to help. I was told I had to make an adjustment directly at the clutch...that means droping my loader. Have you found out what it took to fix yours? (B4 I go to the trouble of taking the loader off and "trying" that.)
LANCE
01-15-2001 20:45:24
CHECK MY FOLLOW UP TO MF 30B I THINK YOU HAVE THE SAME PROBLEM .TRY TO FIX SOON SO YOU DONT HURT PTO GEAR .GOOD LUCK LANCE
poncho
01-17-2001 08:29:51
 Re: Re: MF 175 PTO in reply to LANCE , 01-15-2001 20:45:24
Lance
It's not grinding at any point, and by pushing the clutch in while it's engaged it does stop the pto? It's just I can't engage the pto with the clutch in while the tractor is running..? I have to shut off the engine, engage the pto, then start the engine and the pto works.
thanks any other comments
LANCE
01-17-2001 18:48:04
 Re: Re: Re: MF 175 PTO in reply to poncho, 01-17-2001 08:29:51
PONCHO I THINK YOU PTO CLUTCH IS OUT OF ADJUSTMENT.THIS A VARY COMMON PROBLEM WITH THE TWO STAGE CLUTCH YOUR TRACTOR HAS.YOU MAY TRY TO ADJUST LINKAGE ON CLUTCH PEDAL.TAKE SOME OF THE PLAY OUT OF PED AND SEE IF THAT HELPS. GOOD LUCK LANCE
