OIL PRESSURE
OKIE DOKIE
08-21-1998 07:12:56
I have a Massey-Harris 50 with a Continental Z-134 gas engine. The oil pressure seems to be getting low according to the gauge at operating temp.,
does not fluctuate but shows on the low side of normal operating pressure.
I have Penzoil 30WT in it with less than 20hrs. Problem was there prior to
oil change, Thanks for the help.
Gerald
08-21-1998 07:24:21
 Re: OIL PRESSURE in reply to OKIE DOKIE, 08-21-1998 07:12:56
: I have a Massey-Harris 50 with a Continental Z-134 gas engine. The oil : pressure seems to be getting low according to the gauge at operating temp.,
: does not fluctuate but shows on the low side of normal operating pressure.
: I have Penzoil 30WT in it with less than 20hrs. Problem was there prior to
: oil change, Thanks for the help.
Low oil pressure comes from a combination of three things on an old engine: bearing wear makes for big clearances and oil escapes easily, worn oil pumps have big clearances and so the oil leaks back in the pump, and the spring in the pressure control valve has weakened with age. First thing to do is to adjust the oil pressure control (sometimes called pressure relief valve), usually with a shim under the spring to raise the system pressure. If the pump won't do it then its time for a pump and likely rod and main bearings and maybe camshaft bearings. Also worth checking the rocker arm shaft to see that its ends are plugged. The original plugs are corks and this Continental engine has a propensity to loose them and then loose oil pressure to the rocker arms which leads to breaking off the anti rotation pin and that restores oil pressure to the rest of the engine by shutting off oil to the rocker arms which shortens their life and new ones are very hard to find.
