Massey Ferguson 65/ rear wheel adjustment
Rich M
01-10-2001 13:59:21
Am currently trying to move out rear wheels on MF 65. Probably haven't been moved in 25 years. Need the socket type wrench for the rim stop screws and eccentric pins. Have the ext. handle. Any ideas on gettimg pins loosened up? Thanks!
Larry
01-10-2001 17:54:05
 Re: Massey Ferguson 65/ rear wheel adjustment in reply to Rich M, 01-10-2001 13:59:21
If the wheels are rusty,as mine were,the best thing I found to do is remove the wheels,and un-bolt the center of the wheel.This will let the center drop out .Then remove the "C" clips from the eccentric pins.Ifthey are really rusty,you may have todrive the eccentric pin out.Wire brush them,and re-istall them using anti-sieze.Did this to mine and haven't had a problem moving them since.Also be careful if you try to move pins when they are rusty ,the heads like to snap off.
Larry
01-10-2001 17:51:27
