MH Pony Fuel Value and Bowl Assembly
Dave Bryant
01-10-2001 10:03:04
My Pony would not run for long periods of time without quiting. Wait a few minutes and it would run again. Problem? Not enough fuel.
I removed the fuel bowl and valve assembly, cleaned it and reinstalled. It ran fine. Then the old fuel bowl gasket tore and fell into the bowl. I found a new gasket but it was a little too big. I trimed it to fit and installed.
Now, I am getting even less fuel and noticed that the bowl filled up very slowly. I actually put air pressure in the tank (by blowing hard into it) and it filled up some faster.
I am tired of this and wanted to buy a complete new assembly. Could not find one.
Can someone give me a reference as to where I can purchase a new assembly? Or can I find new "properly" fitted gaskets for the bowl and valve? I suspect the little gasket in the valve is causing this since it looked so bad when I disassembled the valve. This valve also leaks when turned on.
Thanks
Ken
01-10-2001 20:39:24
 Re: MH Pony Fuel Value and Bowl Assembly in reply to Dave Bryant, 01-10-2001 10:03:04
I have used a sediment bowl assembly from a lawnmower shop and also one from a NAPA store. I couldn't find a Tillotson like original.
Ken
01-10-2001 20:38:14
Jason
01-10-2001 15:56:24
Dave,
Try getting your fuel bowl filled up to the top before you put it back on. I had the same problems on different types of tractors. Doing this sort of get the air pressure out of the bowl and inproves flow. I will look in some of the parts books I have to see if I can find any new assemblys. My Pony has a plane old valve under the tank and a inline fuel filter and that seems to help. I will let you know if I find any thing
Dave Bryant
01-11-2001 06:32:02
 Re: Re: MH Pony Fuel Value and Bowl Assembly in reply to Jason, 01-10-2001 15:56:24
Thanks to all.
You have confirmed my findings, that I will not be able to find an original replacement (or at least easily). I will try NAPA as well as another remove and reinstall. Maybe I will use a small o-ring for the valve leakage.
Dave
