Jammed gear lever and brake drums
culla
01-08-2001 07:18:59
Two question on MF tractors.
1. What need to be replace to do away with gear sift lever locking or jammmed.
2. Will the brake drum on MF tractor (if it is in good condition) be able to make a u turn on one wheel like the MF tractor with disc brake?
Thank you all.
Gavin
01-10-2001 09:32:37
 Re: Jammed gear lever and brake drums in reply to culla, 01-08-2001 07:18:59
Q1. There is a spring that holds a catch that goes into a notch on each shifter rail. Easy to replace the spring except that hte steering box is on top.
Q2. yes
john mcgarry
06-03-2002 01:16:26
 Re: Re: Jammed gear lever and brake drums in reply to Gavin, 01-10-2001 09:32:37
hi Gavin, I have the problem of gear getting stuck in second and jumping out of all the others
I've got the top off and 2 of the springs were missing an expert on tractors told me the springs will get rid of the jumping out as the 3 little metal points are still in there ok but it will not stop the 2nd gear jam more likely to need a bearing replaced should I take a chance and put back with new springs to see if it rids me of the jaming too? thanks in antisipation. john
