MH 444 Questions
Tim Essenmacher
01-06-2001 19:41:35
There is a MH 444 For sale around the corner that I'm interested in. It has a loader on it and it's gas. There wasn't a MH dealer in my area when I grew up so I'm not that fimiliar with the brand. What's the horse rating? Is there anything special I should look out for? It looks like it takes two batteries. Was this two six volts hooked in series to make twelve volts? Thanks Tim
Dick B (IL)
01-12-2001 18:38:28
 Re: MH 444 Questions in reply to Tim Essenmacher, 01-06-2001 19:41:35
Yes, two 6 volts will make a 12 volt.
Does it run well with no smoke?
Check for any unusual noises in the transmision,
clutch operation, steering, etc. Massey transmisions will whine some, nothing unusual. Does it have live power take off? That will be a vertical control lever coming up through the right platform. Check it to see if it works smoothly, stopping the tractor when activated. How are the brakes? A very important item would be the hydraulic system. Pull the reservoir cap in front of the radiator and see what the fluid looks like. Put a load in the bucket and see what it does. Some 444s had 3 point hitch, if this one does check it out as well. What part of the country are you in?
Dick B (IL)
01-12-2001 18:36:17
