Hi there, I shall not say what oil you shall use on the engine, as it is a Continental engine. But on the diff., transmission, and hydraulics which use the same oil you can use a common SAE 15W-40 engine oil. The best thing with this is that you have an engine oil, typical 15W-40 in the summertime, and you use the same thing on the rear end. You can always use a grade 80 to 90 gear oil on the diff., trans. and hydraulics, but it is handy to have only one oil. If you choose to use a gear oil you must never put on an EP or hypoid oil. NEVER !!! Note!!! There are 3 holes to drain oil from under the tractor, front is under the transmission, middle under the hydraulic pump cover (aluminum) and the last and sometimes the most hidden under the differential. If you have a hitch you may need to lower it t see the drain plug. I really searched a while before I found this last one. Almost given up.... when I discovered it on the film I have where they assemble the tractor and I noticed the hole. Happy hours with your new tractor. Bill : Hi folks,
