to 20 hydraulics
Jerry in Rhinel
05-19-2008 16:42:32
Need advise!! Linkage disconnected from lift control lever. Having trouble removing pan where you drain the hydraulic oil from. Pan is loose but I can't remove it. Is there something internal that has to be disconnected in order to remove this pan?
marlowe
05-19-2008 20:30:11
 Re: to 20 hydraulics in reply to Jerry in Rhinelander, WI, 05-19-2008 16:42:32
are you talking about the pan on the bottom of the trans if so did you pull the PTO shaft ? it will have to come out because it goes in to the pump and the pump is built in to the pan also did you unhook the wish bone? or control lever from the wish bone?
05-20-2008 05:40:22
 Re: to 20 hydraulics in reply to marlowe, 05-19-2008 20:30:11
In response to the reply regarding to 20 Hydraulics, If you have a Ferguson Owners Manual, the hydraulics diagram is on pg. 28. The pan is located directly below the side cover where the dip stick is for checking hydraulic fluid. I can see the linkage that is disconnected through this dip stick inspection cover. I can reach disconnected linkage through a 2 inch drain plug but need to remove pan in order to fix the problem.
