MF65 difflock
Ed M
05-18-2008 07:02:29
Is it feasible to add a diff lock to my tractor.Would it be somewhat reasonable ?
DavidP, South Wales
05-18-2008 11:03:28
 Re: MF65 difflock in reply to Ed M, 05-18-2008 07:02:29
Hi Ed,
Surprised that you do not have a diff lock on the tractor. Assume there is no pedal coming forward from the RH axle housing. Probably the housing would be the same. Will probably have a plug fitted but if it is very early it may not have a mounting point so you may need another axle housing. Obviously you will need the pedal and linkage. You may also need to change the differential if the dog clutch part is not present and cannot be bolted to yours. If you change the differential this throws up another problem. The diff bearings are pre-loaded to each diff. Fit another one and the shim pack is likely to be different.
Cheers
DavidP, South Wales
Ed M
05-18-2008 19:14:56
 Re: MF65 difflock in reply to DavidP, South Wales, 05-18-2008 11:03:28
Why did you have to throw a monkey wrench into my dream ????? LOL
