MF 65 tranny drain
Ed M
05-17-2008 21:02:33
I have jacked up the front and jacked up the passenger side trying to get all the oil out,but always seem to have a little milkyness when I fill it.Should I just let it drain longer ?
Jeff-oh
05-20-2008 05:48:21
 Re: MF 65 tranny drain in reply to Ed M, 05-17-2008 21:02:33
Ed,
Here is the cleaning procedure I used on my MF-65. The kerosine/diesal reall rinsed her out. And you are right oil drains for a long time.
Jeff
Mike armstrong
05-19-2008 07:51:43
What oil do you use when refilling? the manual calls for SAE89 "Mineral" oil. According to Ford tractor owners that is common 80/90 gear lube. Is this correct? This tractor is a MF35.
Ed M
05-18-2008 19:19:20
Never noticed 2 in 25 yrs.Always used the drain at the differential.Thanks I will try it.
Don Snyder
05-18-2008 10:51:45
There are 2 drain plugs on the left side, clutch pedal side, under foot board, 1 in transmission housing, 1 in rear end housing, the oil can go from one housing to the other. Hope this helps you.
Jeff Z.
05-18-2008 09:32:04
Never did one on the 65 but the Allis Chalmers C model has 3 drain plugs.
Look over good. May be more than one plug.
