MF 2135 specs
Kevin Koler
05-16-2008 12:32:39
Hi - anyone know what length the RH arm adjustable lift arm should be - bought one at the local farm store but it seems too long because I have it as short as it will go and things still don't seem level(seem too low on the right). Thanks
Retired MF Dealer
05-17-2008 08:12:03
 Re: MF 2135 specs in reply to Kevin Koler, 05-16-2008 12:32:39
What length is the rod on the left hand side,there is a good posibility it may have been changed. If you will measure the left hand rod from the bolt at the bottom to the pin at the top that should give you the dimensions you need.
"Retired"
