massey ferguson tractor 231
oldblue
05-15-2008 19:09:53
I would like to know where to fill power steering pump and what level and viscosity of oil.
Thanks for any help you can give me
MF#1
05-16-2008 13:53:34
 Re: massey ferguson tractor 231 in reply to oldblue, 05-15-2008 19:09:53
I "think" it"s the same as the other 200 series tractors. Use Perma Tran III hydraulic fluid unless otherwise stated in operator"s manual. Simply filling it up doesn"t work, you have to bleed it according to the manual. I use a long, skinny funnel that I "thread" into the opening and turn the steering wheel stop to stop about 7-10 times to get the air out. There will be some spillage.
T.W. (MD)
05-16-2008 09:35:26
The reservoir is located on the right hand side just under the alternator. To fill take out the bolt that is in top of it and that is the fill / level hole. For you exact instructions and correct fluid I would refer to the operator�s manual.
