194-4 front diff problems
vijay
05-15-2008 18:01:38
This message is a reply to an archived post by TomTex on February 12, 2008 at 20:57:05.
The original subject was "Re: MF 35 Injector Pump".
sry abt d chg of topic but i would be greatful for any help at all,i hav a 194-4 massey engine runs well,but the front diff is making a sort of a grinding sound when on 2wd mode,when 4wd is engaged the grinding noise is not heard,i do not no much about this unit only bought it bout 6mths ago,i took the shaft out the one that delivers power to the front wheels and the grinding noise is still there,i jacked up the front off the tractor and spin the wheels and they both span freely no noise was present,when tractor is driven back and fort wit drive shaft out i looked at the coupling that connects the shaft to the diff and it seem to be catching and then slipping,i'm lost any help will be appriciated
Masseynut(Australia)
05-16-2008 13:42:39
 Re: 194-4 front diff problems in reply to vijay, 05-15-2008 18:01:38
First things first, I would drain a small sample of oil from the differential housing, then some from both the final drive housings. Check for any metal flecs or worse still, larger pieces of metal. This may indicate where to start looking. I have heard these centre drive models make crazy noises from the driveshaft in 2WD, when the centre carrier bearing has failed, or the sliding couplers on either end have excessive amounts of wear in them, because in 2WD there will be no load on the shaft, allowing it to "Back-slap" while turning. Check out the oil first though, for piece of mind, cheers, Evan.
