pto on 471
vinnywv
05-11-2008 04:35:37
hello, i have a question concerning a 2005 4x4 471 massey ferguson, i cannot get the pto to engage. all it wants to do is grind away. i looked at the owners manual and it said to check the distance from the top of the clutch pedal to the top of the platform. i did that and it is in spec. anything else to look for?
Brian Allen
05-11-2008 06:35:16
 Re: pto on 471 in reply to vinnywv, 05-11-2008 04:35:37
Try blocking the clutch down over-night, it is probably stuck together (if your tractor doesn't have to many hours on it). The best fix is to split the tractor and replace the clutches.
In the meantime, you may have to shift it in and out of gear before you run the engine.
Be tractor safe.
Brian
vinnywv
05-11-2008 07:02:44
 Re: pto on 471 in reply to Brian Allen, 05-11-2008 06:35:16
hi brian thanks for the quick response. the tractor has 300 hours on it. i really don't want to split the tractor and do that but if i have to i will. let me say this though, i adjusted the clutch pedal the other day to where there was 8.5 inches from top of pedal to top of foot rest and i was able to get the pto in gear not smoothly but it went with just a little grinding, i put it back to 7.5 inches and it won't stop enough to get the pto in gear without the grinding. any comments or thoughts will be greatly appreciated.
