Couple MF 35 ???
Mark (EC,IN)
05-10-2008 18:06:18
On a MF 35 when you are setting still and turn the front wheels, there is a whining noise from the power steering )probably moving also, but can't hear it). It's not real bad, and the wheels turn real east...is this normal?
Also, when you raise the three point hitch it is jerky (kind of chatters). It comes right up but it's not smooth. Is this normal...and if not how bad is it?
...TIA..... ..... ..... ....Mark
Dean
05-11-2008 12:06:37
 Re: Couple MF 35 ??? in reply to Mark (EC,IN), 05-10-2008 18:06:18
Which engine?
Tractors with the 3 cylinder Perkins engine (gas or diesel) have a filter inside the reservoir of the pancake PS pump.
Many owners do not know of this filter so it is rarely changed and usually clogged or disintegrated.
Dean
Wesley Stephens
05-10-2008 19:28:27
what kind of shape is the hyd. fluid in? I've seen a fluid change work wonders. Our 35 has manual steering, but on our 135 the power steering is independent of the lift. I'm pretty sure other models are the same way.
