1986 Massy Ferguson 1030 Oil Pressure Problem
dpal
05-10-2008 12:44:48
My oil light does not come on when the tractor is cold, but shows at idle when it gets warmed up. I shows at increasing rpm's as the tractor gets warmer - I shut it down then. Plenty of oil in engine. I changed the oil and filter but did not fix. Next I guess I will change the oil pressure sending switch. Do not have a oil pressure guage to test, but what should the pressure be if I can scare one up? Hope it is not the pump. Any suggestions. tractor has 1,000 hrs.
marlowe
05-10-2008 17:56:37
 Re: 1986 Massy Ferguson 1030 Oil Pressure Problem in reply to dpal, 05-10-2008 12:44:48
what wt. oil are you useing?
dpal
05-15-2008 14:19:00
 Re: 1986 Massy Ferguson 1030 Oil Pressure Problem in reply to marlowe, 05-10-2008 17:56:37
I am using Delco 400 15/40 heavy duty oil.
I have since put a universal oil pressure guage on the engine along with the oil pressure switch. The pressure shows at 60-70 cold. I have not had enough time to run it yet to get it good and hot.
I can"t wait to see what the oil pressure is really doing!
