Massey 1155 leaking oil. PLEASE HELP!!!
kippster
05-09-2008 19:01:36
I have an 1155 massey ferguson with the v8 perkins in it. It also has the multi-power transmission. The tractor sat for about 4 years before I bought it. The thing runs like a bear but the transmission is leaking oil into the clutch housing. I have tried replacing the reverse seal on the input shaft, the o-ring seal on the line for the multi-power, and I already had to put a clutch in it because of the trans oil, to the tune of about $500. I am pretty sure that the oil has to be coming from in between the pto input shaft and the input shaft of the trans, but where is the seal that I need to replace to make the dang trans oil stop leaking into my clutch housing? Any ideas would be appreciated. Thanks guys. Kippster
Holm
05-10-2008 10:36:59
 Re: Massey 1155 leaking oil. PLEASE HELP!!! in reply to kippster, 05-09-2008 19:01:36
There is a seal in the trans input shaft that is probably bad.You will need to pull the front cover to replace it.There is also a tube with an oring on each end behind the seal in the input shaft.If your MP works ok,the orings should be ok.Part # for the seal is 833191m1.
