MF 285 PTO clutch
Ellis -Virginia
05-09-2008 09:30:29
My pto clutch has gone bad three times and I was wondering if anyone knew of a replacement that would hold up? The dealer put in a up grade kit but it went bad also.
Roy Lemmond
07-02-2008 18:30:25
 Re: MF 285 PTO clutch in reply to Ellis -Virginia, 05-09-2008 09:30:29
I have a MF 1085 with similar problems. I have owned this tractor about 6 mos. and dug about fifty post holes and the pto worked just fine pulling the digger, but when I hooked a rotary mower up to it it wouldn't pull it fast enough to cut grass. The tractor is in the shop now and is split. The mech said it needs a new clutch pack. I hope this fixes it.
Ellis -Virginia
05-14-2008 05:43:33
Still no ideas?
Don-wi
05-09-2008 23:11:01
What kind of implements are you running on it? If it's something that acts as a big flywheel and turns the shaft after you shut the pto off, that's whats killing your pto.
We had to use our 285 a few years on the silo blower and the pto clutch & brake took some pretty bad damage during those couple years.
Donovan from Wisconsin
Ellis -Virginia
05-10-2008 12:29:44
 Re: MF 285 PTO clutch in reply to Don-wi, 05-09-2008 23:11:01
I've been running a 10' Woods 121 mower with slip-clutch with a slip clutch at tractor end also but the little pins want take the pressure
Janne
05-11-2008 03:07:39
 Re: MF 285 PTO clutch in reply to Ellis -Virginia, 05-10-2008 12:29:44
Hi!
Do you mean that the slip-clutch on the mower can"t take the beating, or is it the pto clutch on the tractor that"s breaking up constantly?
Janne
Ellis -Virginia
05-11-2008 05:23:04
 Re: MF 285 PTO clutch in reply to Janne, 05-11-2008 03:07:39
I'm talking about the internal pto clutch operated by the hand lever-the one requiring the tractor to be broke in half to replace
