Air Brake system for tailer
Genna Churches
05-09-2008 05:08:18
Hi all you tractor lovers. I have a lovely MF 590 tractor and a fantastic new 3 tonne tipping trailer that was supposed to have hydraulic brakes BUT it has been shipped to me with air brakes. Several people have told me that I can fit a compressor and air brake system to my tractor but who makes them and where do I find one? If any one has some info it would appreciated.
richardinnz
05-10-2008 04:08:33
 Re: Air Brake system for tailer in reply to Genna Churches, 05-09-2008 05:08:18
It will be cheaper and easier possibly to convert the trailer to hydraulic brakes by replacing the air brake chambers with a spring loaded trailer brake ram if possible. I was going to suggest a Perkins engine driven compressor but you will have a power steer pump stuck in the accessory drive position on the engine, so you will probbably have to use a belt driven compressor using an accessory drive pulley bolted to your existing crank pulley, or a pto driven unit.
Genna Churches
05-10-2008 05:13:22
 Re: Air Brake system for tailer in reply to richardinnz, 05-10-2008 04:08:33
Thanks for your info - if I go down the belt driven compressor path do you know who makes them? Do Perkins make one? But I certainly will look at changing the air chambers.
