MF 1250 Power Shuttle
Don Martin
05-08-2008 11:54:39
I have a MF 1250 with a Power Shuttle that won't go into forward or reverse. I was bush-hogging at the time and switched direction without pushing in the clutch. It had a new clutch, pressure plate, etc. installed about 50 hours ago. I checked the wires underneath and made sure they were all intact and attached. I also took the covers off the steering column to have a look. My service manual only mentions a shuttle cable and not a Power Shuttle (with contact position switches). I didn't have a meter with me at the time to check to verify they were working properly. Didn't know if there was some kind of overload fuse or valve, since I was using the power shuttle while the engine was running at a high RPM - running the PTO. Help
Don Martin
05-20-2008 08:30:42
 Re: MF 1250 Power Shuttle in reply to Don Martin, 05-08-2008 11:54:39
For the "who cares" file -
The problem turned out to be a blown 10 Amp fuse - not on the main fuse block.
