Help ID TEA S/N 313176 Engine Crankshaft specs
Ted Stark
05-06-2008 16:37:50
I've got a Massey Ferguson tractor s/n TEA313176 in need of crankshaft grinding/replacement and bearings. I&T manual calls for 2.250" crankshaft journal diameter and 1.937" crankpin Diameter for TE20, TO20 & TO30 engines. Actual measurements are 2.447" to 2.449" mains and 2.0445" to 2.046" crank crank arm journals, ie. bigger than specs. The journal bearings are marked .040" main and .030 crank arm. Other engine information:
4 cylinder gas engine 85 mm cylinders
On engine block: DA12361 300508 3092
On bottom of block : D58
On crank shaft: 58142 10810300SB
On head: 212X
On oil pan: 2 Marshall 59323 AF
Can anyone please help identify this engine and the crankshaft/bearing specifications needed?
Thanks very much for any help provided.
Best regards,
Ted Stark
Wyoming Pa
[email protected]
richardinnz
05-07-2008 04:37:04
 Re: Help ID TEA S/N 313176 Engine Crankshaft specs in reply to Ted Stark, 05-06-2008 16:37:50
You have a British built Ferguson TE-A 20 with a Standard motor Co petrol engine. Check Bare-co, they have a web site and supply the U.S. market. Their engine rebuild kit can be had with a new crankshaft, their prices are very competitive, I just had a kit for a M-F 135 diesel and I had change from $1500.00 N.Z. including tax, and that was with a new crank.
