MF 200 loader fluid capacity
Dax DeCelle
05-06-2008 13:40:09
Does any one know the fluid capacity and filter model for the 200 Loader? I also have the 220 backhone if that makes any difference.
chuck bergstrom
05-06-2008 18:07:32
 Re: MF 200 loader fluid capacity in reply to Dax DeCelle, 05-06-2008 13:40:09
Dax, The total for both is 13 gallons. At the pivot point where the boom meets the subframe of
the loader( RH side) there should be a breather
(pipe threaded )into an adaptor that threads into
the subframe. When you thread the breather off
there should be a dipstick hanging down to check.
As long as there is enough oil to operate all the
cylinders without starvation (jerking) you should
have enough oil in the unit. Chuck
