6 volt to12 volt starting
Ralf from MICH
05-05-2008 05:38:30
Switching my 33 over to 12 volt, went and got a rist. to step it down but someone told me I need to put on a 12 v. coil. Is this correct? I thought the reason for the rist. was to step it down for the points. However if I change the gen. to 12v should I need the rist? Would this not be a 12v sys? or am I missing something? Thanks.
coilboy
05-06-2008 20:10:16
 Re: 6 volt to12 volt starting in reply to Ralf from MICH, 05-05-2008 05:38:30
Typically, a 12 volt coil system actually runs at about 9 volts, due to the resistor, so the points live longer. The 3 extra volts seems to be okay for 6 volt coils.
I changed my 30 over to 12 volts and used the original coil with no problem.
Jeff Z.
05-05-2008 06:48:34
You can get a 12 volt coil with a built in 3 ohm resistor at most auto part stores. Or call John Brillman at The Brillman Company.
He has them in stock.
1-888-274-5562
Ask John to send you one of his catalogs.
You need the resistor to keep the points from seeing 12 volts. I always use the coil with the built in one.
Jeff Z.
05-05-2008 06:56:00
 Re: 6 volt to12 volt starting in reply to Jeff Z., 05-05-2008 06:48:34
Just wanted to let you know if you call John about buying a coil he is always happy to answer any electrical question.
I buy all my tractor electrical products from him. His catalog is loaded with stuff.
t martin
05-05-2008 06:23:03
You should get a 12v coil. With a negative ground system the negative pole of the coil will go to the distributor. With a postive ground system the positive pole of the coil should go to the distributor. Make sure this is correct or you will burn up points.
