water pump 175
lstra
05-03-2008 20:16:16
The water pump for engine cooling started leaking & making noise on my MF 175, it has a 4 cyl. Perkins. Can I get the pump or fan & pump out or will I have to remove hood and radiator for removal & replacment? Any help and advice appreciated. Thanks
lmartine3
05-04-2008 04:56:22
 Re: water pump 175 in reply to lstra, 05-03-2008 20:16:16
If the pump is anything like my 165, it will come out (barely!) without removing the radiator but you need patience to get the four bolts on the fan off. Put a thin piece of cardboard over the rad fins in front of the pump/fan, it does not take much wrangling with the fan to damage the fins and cause a leak. Been there, done that.
Masseynut(Australia)
05-04-2008 03:17:31
It is possible to remove the pump, without taking off the bonnet, etc. the most difficult part is removing the four bolts retaining the blades to the hub. If they have spring washers, it should not be so hard, but patience is the key. The pump can then be unbolted from the engine and removed from the side. The cowling remains in place. regards, Evan.
DavidP, South Wales
05-04-2008 03:38:03
 Re: water pump 175 in reply to Masseynut(Australia), 05-04-2008 03:17:31
Hi,
Would absolutely agree with Evan. Patience is the key. You will find it easier to remove the dynamo and side panel first. A good fitting spanner and a cup of coffee will help. It's a great saving when you consider the amount of work to remove the bonnet and radiator. Add to that whatever is involved if you have a cab fitted.
Cheers
DavidP, South Wales
jogl
05-04-2008 03:12:44
I changed the pump on our 175 a couple years ago and I'm sure that I did not remove the radiator. I probably took off the sheet metal, I've got to the point now where I always take it off first.
JP.
