MF-35 Oil Pressure psi
maxwell99
05-03-2008 18:25:50
Neighbor has a MF-35, about a 1960 model with a Z134 gas engine.
The orginal oil gauge has been replaced on the tractor with a gauge that reads in psi.
His oil pressure runs about 20-23 psi.
Today, he ask me if this was normal oil pressure for this tractor.
I have a TO-35, 1957 model, but my tractor has the orginal oil guage, it reads low, normal, high, so I do not know the normal reading in psi.
Does anyone know the normal oil pressure (psi) for the 1960, MF 35?
Thanks,
BRH
05-05-2008 13:43:47
 Re: MF-35 Oil Pressure psi in reply to maxwell99, 05-03-2008 18:25:50
I have a MF 40B that has 40+ psi for about 20 minutes run time, then drops to 3-4 psi. I changed the PSI gauge with no change, and now just work the loader/box blade for short times.....
I"ve had the tractor over 20 years and it runs great. This started about 12 years ago.
Any ideal what is going on?
Jerry/MT
05-04-2008 11:11:23
The owners manual or shop manual should have this info for you or you mgiht do an aarchive check. While i don"t know the spec values for the Z134,but its "sister engines" are the Z120/Z129 series, they have a pressure of 25-30 psi as normal with no less than 15 psi and 400 engine rpm at operating temperature. Based on this I"d say that 20-23 was acceptable.
maxwell99
05-04-2008 16:28:16
 Re: MF-35 Oil Pressure psi in reply to Jerry/MT, 05-04-2008 11:11:23
Thanks, Jerry,
I will pass the infomation along to him that he is ok on oil pressure.
