3pt harrow disk
prnstr
05-01-2008 18:44:35
ok just bought a 6"10" harrow disk. should the front row of disk face so front edge of disk is toward the center and back row reverse of that?? front //// back //// my best picture
Devin Sparks
05-03-2008 12:45:13
 Re: 3pt harrow disk in reply to prnstr, 05-01-2008 18:44:35
MF Poor,
That is a nice looking MF that you have . Is it a 165? Gas or diesel? I would guess diesel because of the exhaust being on the left. Any way it looks very nice.
MF Poor
05-03-2008 13:30:46
 Re: 3pt harrow disk in reply to Devin Sparks, 05-03-2008 12:45:13
third party image
1971 MF150 diesel, 8-speed
MF Poor
05-02-2008 02:57:43
third party image
Uhhh????? WHAT?
Anyhow, here"s how it SHOULD look.
Brian Allen
05-02-2008 15:17:02
 Re: 3pt harrow disk in reply to MF Poor, 05-02-2008 02:57:43
I just had one of these given to me.
(or at least I think it is the same)
It needs a lot more work, could you send me more pictures of this disc?
Is there a model or serial number on these somewhere?
Be tractor safe
Thanks in advance.
Brian
MF Poor
05-02-2008 15:52:40
 Re: 3pt harrow disk in reply to Brian Allen, 05-02-2008 15:17:02
third party image
It's a model #25 Massey Ferguson disc. Earlier versions came with 6" disc spacing. They're easily identifiable as the scraper mounting bar is a smaller piece of channel as opposed to later 7-1/2" spaced versions having an angle iron scraper bar. The 7-1/2" version came in 3 widths. 8'-10", 7'-8" and 6'-6". Normally, so long as it hasn't been removed, the ID tag should be on the 3-point hitch mast, on the right side. (a 2" X 3" black aluminum plate)
My email is open. If you want more photo's, send email addy and I'll show you all the photo's I have.
MF Poor
05-02-2008 15:59:01
 Re: 3pt harrow disk in reply to MF Poor, 05-02-2008 15:52:40
third party image
Mine began life as an 8'-10" version. I needed it smaller to legally trailer with it mounted on the tractor. I removed the axles, cut them down 7-1/2", rethreaded them, then re-assembled with one less spool and disc blade per gang. Now have a 7'-6" version. (typo in above post. 7'-6" NOT 7'-8")
Here's a photo of what I started with.
MF Poor
05-02-2008 16:07:08
 Re: 3pt harrow disk in reply to MF Poor, 05-02-2008 15:59:01
third party image
I've owned several 3-point mounted disc's. I've never been real impressed with any EXCEPT this #25. They cut like a much heavier disc, leave a nice level seedbed, and with it's short coupled design, they don't overload the tractor in transport position.
This one has the gangs "locked" in place (w/ an extra bolt) remove that bolt and each gang can float somewhat independently of the others.
maxwell99
05-01-2008 21:08:37
look up on yahoo:
disk should look like this Altas 300
http://www.sweettractors.com/New%20Equipment/Tillage%20Equipment/liftdisc2018tubular.html
