Loader control arm help?
Dale in WV
05-01-2008 09:01:10
third party image
I've put a pix in Tractor fotos for the MF-150. It has a "Superior" loader, as an aftermarket attachment. When I drop the loader, it doesn't go all the way to the ground -- I can tilt the bucket and hit the ground -- even lift the tractor that way, but the loader seems to bottom out with about six to eight inches of the cylinder's tube still exposed. Any adjustments that I can make to get it to drop further -- without major work?
I can see from a previous paint job that it's been that way for a while. Just not sure why its that way.
DavidP, South Wales
05-01-2008 10:46:45
 Re: Loader control arm help? in reply to Dale in WV, 05-01-2008 09:01:10
Hello,
I assume you have checked that no part of the loader beam is striking the front guard area of the bonnet. If this is clear and the loader stops 'solid' every time it reaches that point then someone might have fitted some packings of some sort inside the cylinders and under the piston to limit the amount of return travel. Remove one of the rams and check for a 'solid' stop.
DavidP, South Wales
