44 Special- -Help Needed
waclar
04-28-2008 18:20:10
third party image
third party image
third party image
third party image
third party image
Special with live pto, took live pto clutch and brakes apart. Brake disc's were past worn out and clutch release backing plate (1005527M1) was cracked and had grooves worn into it from rivets from worn-out brake disc. I'll try to attach a picture, was wondering if anyone has run into this before. Haven't checked with machine shop to see if they can help yet. Anyone know where a replacement backing plate might be had? Not sure if 444's used the same plate or not. Would assume prior 44's that didn't have disc brakes wouldn't have same plate but not sure. Thanks in advance.
chuck bergstrom
04-28-2008 18:47:00
 Re: 44 Special- -Help Needed in reply to waclar, 04-28-2008 18:20:10
Hi, The 333 and 444 have the same part no. disc.
Also there is a complete assembly p/n 764 803M91
in Chilton, Wi. You can have any local dealer
call them at 1-800-743-3768 or www.depotparts.com
and get a price and or order. If you don't need
the live PTO, there is a way to block unit together. I just don't recall but maybe has some-
thing to do with removing the spacers??. That just makes it a solid unit. Chuck
