MF-35 Clutch Job
Hobo,NC
04-27-2008 18:16:13
1958 MF 35 gas,,, does it matter witch way the solid center clutch disc go's,,, when i removed the engine and took the clutch apart I for got to mark it so I am unsure of the way it was turned,,,, I also am replacing a badly worn center axle pin,,, not much of the bushing left so I will have to git a new one to see how it fits,,, I take it that it only has one bushing,,, not 2,,, although it looks like theirs room for 2 or a longer one than whats in the axle,,, thanks much
TEXAS TIM
04-27-2008 22:29:15
 Re: MF-35 Clutch Job in reply to Hobo,NC, 04-27-2008 18:16:13
i have only replaced them once usally i just get the whole setup and install it . i found that piecing has created more trouble for me .
Wesley Stephens
04-27-2008 20:07:09
is it possible to just replace the single stage clutch in a MF 35 without a live pto with a 2 stage one or are there other differences?
ford-s
04-27-2008 18:36:52
hobo,the long side of the clutch disk points toward the rear of the tractor.
Hobo,NC
04-27-2008 18:51:14
 Re: MF-35 Clutch Job in reply to ford-s, 04-27-2008 18:36:52
OK, thanks,,, this one has worn the fingers off the pressure plate,,, the release bearing went in 2 far and fudged up the release springs (return springs for the release bearing),,, I was looking in parts books,,, TISCO and Sparex offer the fingers to rebuild the pressure plate,,, I don't plan to rebuild it but was wondering if its common practice to replace the fingers on a MF 35
Brian Allen
04-28-2008 07:05:15
 Re: MF-35 Clutch Job in reply to Hobo,NC, 04-27-2008 18:51:14
You should replace the clutch, pressure plate, throwout bearing and pilot bearing together.
You do not want to take it apart again.
Get a manual, if you do not have one for the split.
Be tractor safe.
Brian
