massey 50 3pt question
Ray
04-27-2008 09:51:52
I bought an old MF 50 diesel the other day.One of the 3pt arms has been broken off.The arm looks good,but the bolt that holds the 3pt arm to the tractor is broken off.How do i fix this?
Does the housing need to be removed? Thanks.
chuck bergstrom
04-27-2008 19:08:28
 Re: massey 50 3pt question in reply to Ray, 04-27-2008 09:51:52
Yes Ray, The side housing must come off. The pin that comes out of the housing is tapered with a nut inside the housing. Not a major job
tho. Be sure to drain the oil first, remove the
wheel and tire to make handling easier, then un-
bolt and slide the housing off. Then you can get
at the nut. If nut is original it will have a cotter key thru it. Chuck
Ray
04-28-2008 18:20:32
 thanks,Ray in reply to chuck bergstrom, 04-27-2008 19:08:28
th
