massey ferguson front end loader for 165 diesel
mark volkmann
04-25-2008 19:00:29
i have a 165 perkins and a model 99 massey ferguson front end loader. is it possible to retro fit this loader to my tractor the loader pump sets in front of the radiator . can i get a pulley that will accomidate a fitting that will allow me to run the pump off of the front of the drive shaft
Bob N.Y.
04-26-2008 16:30:54
 Re: massey ferguson front end loader for 165 diesel in reply to mark volkmann, 04-25-2008 19:00:29
There should be 3 or 4 tapped holes in the crankshaft pulley. You need a plate with a splined hub that matches that bolt pattern to drive the pump shaft.
135 Fan
04-26-2008 11:17:05
Check on the archives on here. You need to modify a steering arm so the tractor has full turn steering both ways. I think the pulley and pump coupling is available but the special steering arm isn't, but could be wrong. Others on here will be able to tell you more. Dave
Bob N.Y.
04-26-2008 16:27:26
 Re: massey ferguson front end loader for 165 diesel in reply to 135 Fan, 04-26-2008 11:17:05
That was a problem with the early 65s. It was corrected on the late 65s and 165s.
