4 cyl 1958/9 fe35 ring job - sump removal
Steven Young
04-22-2008 08:35:09
First off .. thanks fot a great site.. I have learned and saved a lot from these discussions.
Having said that.. gotta do rings.. the manual says to drain the cooling system also.. to pull the sump/oil cover.. ??
I have a front end loader and see that there are two LARGE bolts going into the thick re-inforced front part of the pan. Can the pan be removed without removing the whole front axle support - or can I just prop up the stuff around it and remove the two LARGE bolts during this ??
sibby(AUS)
04-25-2008 06:07:23
 Re: 4 cyl 1958/9 fe35 ring job - sump removal in reply to Steven Young, 04-22-2008 08:35:09
steven, the 23c diesel is an english standard engine, similar to the engines fitted to the old black taxi cabs. parts are getting scarcer and very expensive down under. the 3 cylinder perkins is a much more popular choice, very cheap to repair, very easy starting engine and easy to get parts. cheers for now. sibby.
Steven Young
04-25-2008 04:34:12
Thanks for your replies. Ater pulling the head off , it turns out the head gasket is shot .. it's leaking back & forth between two cylinders (no wonder it won't start). Someone at Massey's design area needs a good SMACK for putting the cylinders so close together that there is only 5/16 of an inch or gasket material...DOH.
sibby(AUS)
04-24-2008 21:54:31
steven,remove the oval oil strainer plate before dropping the oilpan. cheers.
TEXAS TIM
04-24-2008 20:46:27
the pan can be removed without taking the loader off . but i would suggest no encourage you to remove it . oil sump is in the bottom of engine an will be in the way if you remove the rods . good luck
