gasoline hook to LP carb ??
Jerry C Okla
04-21-2008 08:55:48
Out of propane,Can I unhook the line from the regulator and hook a gasoline line to it and start and drive on to trailer ??
i may want to convert to gasoline, do I need to change carb ? thanks Jerry C
Gerald J.
04-21-2008 10:07:43
 Re: gasoline hook to LP carb ?? in reply to Jerry C Okla, 04-21-2008 08:55:48
The LP carburetor probably won't work with gasoline. Though I have one on an Onan generator that is triple fuel.
Some tractors have a port that will take a hose from a BBQ tank for running them back to the main LP fueling station. Or loading on a trailer because that's how the factory did it.
Gerald J.
Jerry/MT
04-21-2008 10:04:43
Usually propane powered engines have a high compression ratio head that may or maynot run on OK on gasoline.You may have to use premium fuel.
The carbs are definetley different because they genrally have a hot water line to the regulator portion of the carb to keep it from freezing up. It wont work on gasoline. Do you have a propane barbecue tank that you can hook up to get it on the trailer?
