35 Steering-again
KY Greg
04-20-2008 05:03:52
Thanks for the beer advise Mr. Allen and Mr. Supergrumpy. Even though it is still bourbon season in KY I will make an exception for the benefit of a Massey Ferguson. If it helps just one the effort will not be worth it all. I promise to do my share to the best of my ability.
Before I do what you recommend-
The left tie rod end connected to the arm from the steering box is showing about 1" of threads. The left tie rod end connected to the kingpin is screwed all way in.
Both right side tie rod ends are screwed all the way in.
The right tie rod tube has a slight bend. Measuring from tie rod shaft to tie rod shaft the left is app. 1" longer than the right (the same amount the left tie rod end is screwed out).
Has this been messed with?
Should I string from the back wheels to get the front wheels parallel with the rears then worry about the toe in?
It has adjustable rear wheels and they are not exactly true. Is that a problem if I do need to string?
How are these set up at the factory?
Do the tie rods need to be different length since the steering arms from the steering box are at different heights?
Thanks, Greg
BOBinKY
04-21-2008 19:45:54
 Re: 35 Steering-again in reply to KY Greg, 04-20-2008 05:03:52
I went back through my books and found that I told you wrong. You want to measure so that the front of the front tires are 1/4 of an inch shorter than the back of the front tire measurement. Sorry about that.
BOBinKY
04-21-2008 12:33:10
Hey KY Greg. I just got done restoring my To 35. What I did and it seemed to work very well was to C clamp a 1X2 over the outside of each tire while the full weight of the tractor is on the wheels. Make sure the 1X2's are level. Adjust your tie rods so that your measurements are 1/4 of an inch wider in the front of the tire than at the rear of the front tire. This will allow the tractor to track without fighting the steering wheel all the time. I'm in Lexington, where are you?
Brian Allen
04-20-2008 08:09:04
Hi again.
You don't need to do anything with the back wheels.
I don't know how they do this at the factory.
Set up as per below. Note that the front wheel bearing must be checked before you start.
I think at this point you should: First verify that your front bearings are OK as I instructed earlier.
Next center the steering by carefully turning and counting turns from full left to full right then bring back to center by number of turns divided by two( be very careful and precise).
This will give you a starting point.
Now, where are your wheels pointed?
Now you can adjust the drag links to bring wheels to the proper toe in (a good soaking of penetrating oil before you start will help get the drag lings easier to turn.)
PS don't drink anything until you are done!
Please re-post and let us know how you made out.
Sorry for the long post.
Brian
