MF 65 Throttle increases
Jeff Ziegler
04-17-2008 16:57:16
I have a 1959 NF 65 that ideals great. If I increase the throttle to 1200+rpm and wait about 30 sec. The RPM jump to over 3000+? Any idea what has to be replaced? All I see from the parts book are the � governor balls, a compression and tension spring, and a spring on the lever. The lever is not moving so it is not the last one. I would rather not pull the front of the engine off to check the � balls. Thanks for any help.
Note: This started after adding a front pump shaft mount to the pulley and NO pump installed. More rotating mass.
