massey ferguson 35 te
walter johnson
04-16-2008 19:25:41
this is a diesel tractor thought i had all the bugs out of it was running good after oil change and fuel filter i turned it off cranks but wont start i had just added 2 gal of fuel i noticed that the fuel bowl wasnt full so i took it off a just a trickle of fuel came out seem like the last time a lot of fuel came out and the bowl filled up fast help
Ducky
04-16-2008 22:24:15
 Re: massey ferguson 35 te in reply to walter johnson, 04-16-2008 19:25:41
You may just have some gunk clogging the strainer inside of your fuel tank. The strainer is above the the shut off valve from the tank. Some people empty the tank and then remove the strainer to clean. A quick way but not recommended for the long haul is to blow compressed air up the tube from your glass bowl. At least this will get the fuel pouring again.
