Massey 65 Diesel ,clutch problems, wont stop
Mike S 806/H
04-16-2008 09:47:51
I have a Massey 65 diesel matic multi-power, problem is when you push in the clutch it wont stop right away, takes about 10 to 15 feet before it stops.
DavidP, South Wales
04-17-2008 00:50:59
 Re: Massey 65 Diesel ,clutch problems, wont stop in reply to Mike S 806/H, 04-16-2008 09:47:51
Hi,
Two possible problems. First you might have a film of oil on the clutch plate which is making it sticky and slow to release. Remove the plate under the clutch housing and using a flashlight inspect the clutch unit for any signs of oil. Blackish oil will be from the engine, clearer from the transmission. Secondly your clutch adjustment might be out. You should have about 1 to 1 1/2 inches of free movement at the end of the pedal. Any more and you may need to go into the second stage before forward movement stops efficiently. DavidP, South Wales
W R
04-18-2008 02:35:21
 Re: Massey 65 Diesel ,clutch problems, wont stop in reply to DavidP, South Wales, 04-17-2008 00:50:59
Siezed pilot bearing.
