1135 with multipower / troubleshoting
RobE
04-12-2008 20:00:06
I have an 1135 with multipower, and sometimes it will slip, it seems to do it when you first give it throttle, mainly in road gear. The tractor will slip for a second, then grab, and take off fine. The thing that confuses me is you can be going down the road, or field smash the brake, and it won't slip, you can pull the engine completely down. This makes me think it may possibly not be the clutch disc being worn. Could it be something in the hydraulics? Maybe not enough pressure? The pressure at the outlets is at 2000 lbs, Sometimes it takes a while for the hydraulics to kick in, and the steering is a little stiff. I thought maybe it loses pressure sometimes and causes the tranny to slip? thanks for the help.
STUDIEDIESEL63
04-13-2008 18:59:21
 Re: 1135 with multipower / troubleshoting in reply to RobE, 04-12-2008 20:00:06
...and clean the charge pump screen in the bottom of the transmission housing .
Wayne IA
04-13-2008 10:43:50
Take the left side tin panal between the dash and cab off and check hyd preasure at the PTO multi power valve. Should be 210lbs, give or take a little at idle with both the PTO and multi power valves applied. When was the last time the hydraulic filter was changed?
