1955 TO 35 oil leak
The JD Workmen
04-06-2008 16:57:34
On the bottom of our 1955 TO 35 there a hole on the botm of the bell housing that drips oil what is the porpuse of it and does oil build up in it when the tractor sits for a while. Where is the oil coming from and is there any way to correct this Thanks for any help.
Jeff Z.
04-06-2008 17:07:20
 Re: 1955 TO 35 oil leak in reply to The JD Workmen, 04-06-2008 16:57:34
It is probably due to a bad engine main seal or a transmission shaft seal.
Jeff Z.
04-07-2008 06:18:41
 Re: 1955 TO 35 oil leak in reply to Jeff Z., 04-06-2008 17:07:20
The only way as per the other post is to split the tractor.
Manual:
http://manuals.us/index.asp?PageAction=VIEWPROD&ProdID=8673
Jeff Z.
04-07-2008 06:23:19
 Re: 1955 TO 35 oil leak in reply to Jeff Z., 04-07-2008 06:18:41
Sorry, wrong manual.
http://search.ebay.com/search/search.dll?from=R40&_trksid=m37&satitle=Ferguson+to35+manual&category0=
The JD Workmen
04-06-2008 17:18:59
Jeff what is the best way to get to that seal and is there anything to watch out for. Thank you!
Jerry/MT
04-06-2008 17:44:16
 Re: 1955 TO 35 oil leak in reply to The JD Workmen, 04-06-2008 17:18:59
You have to split the engine from the transmission to get access. If you are not knowlwdgeable about this type of work, you need to get a Ferguson Shop Manual( ~$20) to tell you how to do it and what to watch out for. Don"t be afraid to work on this machine. It"s realatively simple machine but you really need the factory shop manual to explain how everthing works, in my opinion.
