Anybody ever install a steering welch plug?
jd4400
04-06-2008 11:33:21
I removed and disassembled the steering gearbox in front of the radiator to replace the leaking bottom seal on an 1155. There is what is called a welch plug on top of the steering box. The genuine Massey shop manual just gives the instructions to install the welch plug. I did that and took a socket about 2/3 the size ot the plug to tighten it up by pounding on the socket. Well it seeps oil. I then looked in the I&T shop manual and it says to apply hydraulic sealant (Brown loctite). Anybody ever install one of these welch plugs? What kind of sealant did you use? How did you expand it to tighten it up around the edge?
RichardR
04-07-2008 07:57:18
 Re: Anybody ever install a steering welch plug? in reply to jd4400, 04-06-2008 11:33:21
My experience with freeze plugs (assuming that they are similar to welch plugs) is to deform the plug by using a ball-peen hammer in the center of the plug. This changes it from being convex to being concave and thus makes a tight fit.
Just my two cents worth.
msb
04-06-2008 21:27:31
Did you clean the welsh plug bore real,real good?
jd4400
04-07-2008 08:15:43
 Re: Anybody ever install a steering welch plug? in reply to msb, 04-06-2008 21:27:31
The bore looked clean, I'll have to pay attention to that. Have you installed a welch plug before? If so did you use any sealant and how did you tighten the welch plug in the bore? Thanks for the reply. I'm heading for town now to try and find some of that brown loctite the I&T manual calls for, that manual was written some 30 years ago they probably don't make the brown Loctite anymore.
