need info for MF 135
John DeSimone
04-02-2008 15:50:32
Hi All could one of you help me with a small problem with my MF 135 gas engine. I need to know which contact on the starter solenoid R or S does the wire for the fuel shutoff solenoid go on. I forgot to mark it and got busy with other things on the farm and now I can't remember where it went. Thank you very much.
JOHN
Gerald J.
04-02-2008 20:18:19
 Re: need info for MF 135 in reply to John DeSimone, 04-02-2008 15:50:32
Neither. It should go to the ignition contact on the ignition switch.
Gerald J.
John DeSimone
04-04-2008 14:04:40
 Re: need info for MF 135 in reply to Gerald J., 04-02-2008 20:18:19
Hi Gerald,
Are you sure the wire goes on the ignition contact on the ignition switch? I thought when I took it off it came off either the R or the S side of the starter solenoid. Thank you.
JOHN
Gerald J.
04-04-2008 16:04:38
 Re: need info for MF 135 in reply to John DeSimone, 04-04-2008 14:04:40
Yes I'm sure. The carburetor solenoid needs power alll the time for the engine to run. The S terminal only has power while the starter is cranking. The R terminal is what makes the solenoid pull in.
The carburetor solenoid was probably a field addition and so its not in the original wiring diagram.
My MF-135 doesn't have that solenoid on the carburetor but my JD-4020 does. It was added in the field too.
Gerald J.
john DeSimone
04-05-2008 19:02:08
 Re: need info for MF 135 in reply to Gerald J., 04-04-2008 16:04:38
OK I will have to find out where the wire was connected on my tractor. I want to thank You for all your help.
JOHN
John DeSimone
04-03-2008 04:57:20
Thank You Gerald!
