MF 135 servicing
Fred 135
04-02-2008 12:31:03
While I"m normallly a ford person I now have to take care of the tractor at my wifes church. I"ve got a pretty good dealership that I get parts from and have a book ordered for it but was wondering if anybody had some tips on serving the tractor? Tanks in advance. It is the diesel engine.
DavidP, South Wales
04-02-2008 14:02:08
 Re: MF 135 servicing in reply to Fred 135, 04-02-2008 12:31:03
Hi,
They really are simplicity to look after. Oil and filter changes are straight forward. Remember there should be a strainer on top of the fuel tap in the tank that does block quite easily with rubbish so its worth checking it at every service as it will only stop when its going!!!!!
Things like clutch and brake adjustment are also easy. If the tractor is not used much, make a point of either jamming the clutch pedal down and leaving the brakes off after chocking the wheels or run and drive it weekly to stop the risk of rusting up. Check inside the rear wheel drums for any sign of oil around the drums. This can happen if the tractor is standing or is over-filled. Everything else is pretty much universal.
DavidP, South Wales
