MF148 Leaking connector on power steering ramGot a new left hand power steering ram (sparex no S.60515 not Massey part) for my 148 but when connecting the lower feed pipe I was able to screw it by hand almost completely home, I have it tightened as much as I dare but it leaks fluid a quite a steady drip !! This scenario strikes me as strange, does this suggest the fitting on the ram is too deep ? or should there be small �O� rings in this joint ? (I see none in my parts book) Also I my steering is now as heavy as lead and making adjustments at the control valve makes no difference. I am as certain as I can be that I have put the pipes on the new ram in the same position as the old one. If I had them backwards would I still be able to steer? Also is it possible that the sparex part has the connectors reversed!! Also I noticed sparex no S.60515 is in the catalogue as a Left hand cylinder equivalent to MF part 1885715M91, which according to my parts manual is a right hand cylinder, I presumed this was just a typo in the sparex catalogue but maybe there is more to it. Any body any experience with these rams ? bg
