Front Pump Mount?
Jeff Ziegler
03-29-2008 17:19:07
How do you mount a front pump to the front axle pivot?
Link
The threaded holes are not centers on the center opening? The after market pumps seem to all mount with 2 bolts across from each other.
Gerald J.
03-29-2008 19:46:39
 Re: Front Pump Mount? in reply to Jeff Ziegler, 03-29-2008 17:19:07
I made a shelf to fit on the 5/8" bolts out front. Then I made a right angle piece to fit the flange of the hydraulic pump that sat on the shelf. I had to shim it up slightly to line up the shaft. It worked several years.
Gerald J.
