MF65 Tractor Diesael Motor
Joe Fortino
03-27-2008 12:57:03
I an trying to rebuild a MF65 Diesel Motor. I has a Perkens block. I cannot find the serial number on the block. I can't order parts without it. I am told that there are two series of motors made by Perkins for that tractor.
Geoff in Scotland
03-31-2008 07:48:38
 Re: MF65 Tractor Diesael Motor in reply to Joe Fortino, 03-27-2008 12:57:03
Joe you are correct....there are 2 diesel engines in the MF 65 the early one was the Perkins 192 engine in the MK1.....the Perkins 203 was in the later MK2
Don_G
03-29-2008 07:06:54
Joe,
Here's a link to a site that shows you where to look for your serial number. You need the number as some parts change by serial number for both regular and direct injection models.
Don
Aaron Ford
03-27-2008 21:25:38
The indirect is called the A4-203 while the Direct injection is called the AD4-203. I think,...
Bob N.Y.
03-27-2008 17:38:09
If the fuel injectors are verticle, it is indirect injection. If they go in the head at an angle, it is direct injection. The direct injection engine has 23 head studs. The indirect injection has something like 17 studs. That is what you really need to know.
