MF 65 brakes
Jeff Ziegler
03-27-2008 12:41:06
i have a MF 65 that I can adjust 1 side fine but the other (passender side) the bolt will not move. If I remove the 2 bolts holding the lever mount can I replace the bolt/shaft without removing the axle? Or is the only way to remove the axle and replace? If I remove the axle and find oil can the seal be easly replaced or does I have to go deeper to replace it?
Bob N.Y.
03-27-2008 17:44:07
 Re: MF 65 brakes in reply to Jeff Ziegler, 03-27-2008 12:41:06
The brake adjusting rod can be changed by removing the lever mount, as you call it, BUT the adjusting nut has to be removed first. Have you tried heat on the nut? The axle housing has to be removed to change the seal.
Bob N.Y.
03-27-2008 17:44:01
