M F 175 HYDRALIC PROBLEM
JERRY PERRY
03-27-2008 08:04:26
I have a M.F. 175,when tracktor is cold the hydrlic 3 point lifts my disc up good,as I keep using it & things heat up the disc does'nt lift very well & finally won't lift at all,does anyone know the problem & cure ? thank you ,Jerry
DavidP, South Wales
03-27-2008 09:10:01
 Re: M F 175 HYDRALIC PROBLEM in reply to JERRY PERRY, 03-27-2008 08:04:26
Hello Jerry,
Sounds like you may have a significant leak in the hydraulic system when the oil is warm/hot and thinner. The most likely place is the lift cover piston, rings or cylinder but there are a lot of other places as well.
If you raise the implement and switch off the engine, does the 3-pt drop quickly? If it does, drain the oil level to the bottom bolt of the right hand side cover and remove it. Repeat the lift again and with the use of a flashlight you should be able to see if oil is leaking from above.
Let us know.
DavidP, South Wales
