Massey Ferguson TO35 Piston Orientation
Duke Clinton
03-26-2008 17:46:03
I am putting new piston rings in a 1955 TO35 and have reason to believe the last guy may have put the pistons in 180 degrees off. There is a small pin hole on one side of the connecting rod for oil at the base. Do you know which side this hole should be installed when you are sitting in the driver's seat?
Don Snyder
04-05-2008 16:17:39
 Re: Massey Ferguson TO35 Piston Orientation in reply to Duke Clinton, 03-26-2008 17:46:03
Duke: The number stamped in the the connecting rod where the bolt goes thru goes on the camshaft side. Hope this helps you. Don Snyder
